I installed my iPad mini in the wall yeaterday so not playing around with it much now. Noticed that in the morning or when I get home from work, Homewave will not talk to the Vera3. The Vera and the iPAD are both on wireless talking to the same access point. When I cannot connect to the Vera with HomeWave I can connect with GrassHopper from my windows phone. Makes me think it is the iPad or HomeWave and not the Vera. First Apple product since my ipod years ago so not sure if there is some setting I need to tweak to keep the network connected or something in HomeWave. When I close HomeWave and open a browser it connects or close HomeWave and reoen it it connects.
Check the Homewave settings for “keep iPhone on” and enable that. If your iPad is plugged in and running HomeWave, it will not go to sleep while HomeWave remains running.
With that said, there is an issue in the network code of HomeWave that sometimes keeps it from reconnecting after being disconnected momentarily. I notice this sometimes on a wall mounted iPhone. Quickest way to reconnect in this case is to tap the red connection indicator, this will trigger a reconnect attempt.
