Had an existing 4 port camera server IP Video. After searching thro forum, found a link to 9100a server. Which I think is the same internals as 9100B, just mounted in a metal case rather plastic.
In the post found reference to upgrade firmware, which would permit access to jpg files.
Download the firmware upgrade from http://9100.yoics.com/includes/builds/yoics9100a_2_47.zip, upgrade worked Ok. Reinforcing the 9100A and 9100b Appear to be same.
files are in /usr/ypics0.jpg this access file from first port the remainig 3 files change yoics1.jpg thro to 3.
if changed to http://192.168.0.20/usr/yoics3.jpg the camera would not add. So left at the default and changed in settings to \usr\yoics1.jpg that worked Ok
add all four ports succesfuly
One camera I have at the moment plays Ok in HomeWave
Hopefully the above will be useful someone
Now for the question
Is there a way to send a notification with a picture of when a PIR was tripped.
I have set up notification to send a text when the PIR has detected moton
Think I’m having a Homer Simpson moment. Scan thro the various posts, found VeraAlerts. Have now setup to send email to my email to sms account. At the same time email me a picture from the camera.
[quote=“jolly1, post:1, topic:177831”]Hi
Just started with VeraLite and Z wave.
I have set up notification to send a text when the PIR has detected moton[/quote]
Hi
I have managed to follow your steps but unable to get the part where you change the settings for: \usr\yoics1.jpg Where do you change this?
If you have added camera to Vera, you should now have four cameras. Click on the setup for the camera (spanner in the top right), select settings tab and scroll down to URL and enter
usr/yoics0.jpg for camera 1
Then on the second camera repeat and enter
usr/yoics1.jpg for camera 2
[quote=“jolly1, post:6, topic:177831”]If you have added camera to Vera, you should now have four cameras. Click on the setup for the camera (spanner in the top right), select settings tab and scroll down to URL and enter
and so on[/quote]
Hi
Another thing as it wont let me upgrade the firmware. I goto the firmware page and select upload firmware and leave it and nothing happens.
problem solved. re-named the camera and it worked. thank you for all your help with this. Now onto the next challenge sending a image to my phone when doorbell pressed
