We recently added an IP camera in Vera, but it is not showing up in ImperiHome anywhere that we can find. We must be missing something somewhere.
Any help is appreciated.
[quote=“SKPnSF, post:1, topic:195387”]We recently added an IP camera in Vera, but it is not showing up in ImperiHome anywhere that we can find. We must be missing something somewhere.
Any help is appreciated.[/quote]
I “think” if the IP camera is not one that is designed to work directly with Vera like the VistaCam and a few others, you would go into Imperihome …Menu > Settings > My Systems > Add a New System > choose “MJPEG/h264/MPEG4 IP Camera”. Then fill out the details and it will be available.
You could also check your general settings to see Hidden groups and Hidden devices by chance it might be.
Thanks for your reply.
I uninstalled and reinstalled and the cams showed up
