Hi ,
Has anyone used the feature in the configuration of the IP Camera that allows you to have a motion sensor tripped and then turn on a light? ( configuration of the IP camera)
I have tried this , it turns on the light but only for a “few” seconds. The motion sensor still shows in the tripped positon!
Does anyone know how to make the light stay on longer?
I have the Hawking motion sensor from Everspring!
Set up a scene (maybe call it “Motion Detected”).
Specify the motion detector you want to monitor.
In the scene, add a command that turns on the light you want when an armed or unarmed sensor trips, and specify how long you want it on and what you want the sensor to do (re-arm, stay unchanged, etc.)
(I only use the camera commands to turn on the lights to take an archive pic, then lights go back off.)
Mistro - Do you have the HRMD1? I just picked this sensor up and it is constant going into bypass regardless if I tell it to arm in a scene.
Aarron or CJ - Have you guys messed with a HRMD1? It from Hawking but the OEM is Everspring.
