I have a meshbot that is triggered by a device turning off (state going to false) then in the action it delays 5 seconds and turns it itself back on (state to true).
The trigger is firing on the turning on of the device and not the turning off. Weird. I have done this before so I thin it is something that has gotten broken in newer releases.
If I invert the trigger by making it NOT the meshbot operates properly as expected/desired. If I try to change the trigger from false to true the save button doesn’t light up so I can’t save it.
So a few things wrong here. The save button lighting up is a recurring problem from >1 year ago I thought was fixed but I guess only fixed for certain cases.
I don’t mean to be critical but this is pretty basic stuff guys…
This version works properly (note the trigger state had disappeared!!!:
There is also some problems in how this saves. Anyway I have to move on and have no more debug time to spend on this basic 101 issue. I suspect the logic saved is different to what is displayed. Maybe a meshbot file corruption or something???
Yes I think you also found out it doesn’t work on the false condition but works on the inverted triggered condition. I found this out by adding a different device for the action and the rule worked exactly inverted. Weird.
