I don’t know why but AUthomation HD dosen’t work anymore for the lasts 2 months and I don’t understand why because I didn’t changed anything…
I read all topics about this subject: i chossed a new passwork, I connected to different serveur such as fwd7.mios.com etc…
I can connect through micasaverde server but some other softwares stop working as well (such as Imperihome) and only veramobile is working remotely (Home buddy is only working through wifi).
Thanks for your help…
You can only connect to the server that your vera is tied to. When connecting to cp.mios.com and selecting your vera, what does the url say? It should show something like fwdX…
Have you tried using the auto connection configuration?
It says fwd7 but when I try to connect with this server it doesn’t work…
As I wrote before only VERA MOBILE is working remotly and HOME BUDDY is working only when I am connected to my wifi. All others are not working.
Don’t understand why it was ok before and why it stopped without any changes…
Anyway thank you for the time you spent to help me
When I set to local it doesn’t work, it says: “An error occured. ERROR: unknown error”
I changed the port from 3480 (auto) to 80 and then i get: “Received invalid json response”
running 3.1.3.5 but my problem is not recent and I think it was the sale with 3.0. Moreover as I wrote before I faced pb with other softwares at the same time
I wonder if it has something to do with your user_data. If that is the case some apps may not be as strict with the json parsing. Would you be wiling to provide me your user_data2? Instructions can be found here:
Hi Garrett. Still no news from your side and i am missing to use your application. Tell me if you don’t have time to have a look on my problem (I can understand that it is waste of time to help someone who is te only one to have this kind of pb).
Anyway thx for this great application !
Seb
