We are excited to announce the ezloPi Home Assistant Integration, now available to seamlessly connect your ezloPi IoT devices with Home Assistant!
What is ezloPi?
ezloPi is a powerful and flexible IoT platform designed to simplify prototyping and building IoT solutions. It provides robust APIs, a wide range of supported devices, and the tools you need to take your smart home to the next level.
To learn more about ezloPi, check out our overview: What is ezloPi?
Features of the Integration
With the ezloPi Home Assistant Integration, you can:
- Control Devices: Easily manage and monitor your connected ezloPi devices.
- Automate: Utilize Home Assistantβs powerful automation tools with ezloPi.
- Real-Time Status: Keep track of device status updates in real time.
- Expand Possibilities: Combine ezloPi devices with other Home Assistant integrations for a seamless smart home experience.
Installation
The integration is available via HACS (Home Assistant Community Store).
Install directly from HACS by adding the repository:
For detailed instructions, check out our GitHub repository:
GitHub - ezloPi Home Assistant Integration
Get Started
- Install the integration via HACS.
- Add the
ezloPiintegration in Home Assistant under Settings > Devices & Services. - Follow the prompts to connect your ezloPi devices.
Need Help?
If you have questions, need support, or want to share feedback, head over to our ezloPi Community Forum:
Weβre looking forward to seeing how you use ezloPi to enhance your smart home! ![]()
Let us know what you think and feel free to share your automations, ideas, or suggestions. Happy automating! ![]()
The ezloPi Team
