Nice to get comprehensive feedback like this
Sounds like a bug. If you exit the app completely and then open it again, the deleted screen should be gone from the swipe rotation.
Thermostats are in Celsius only. I have min/max set on my thermostats, and warnings set up via Prowl, so I can't control the thermostats without setting off warnings (because I can't set the thermostat above 69 deg C). When I set the thermostats to 73 deg F in MIOS web interface, HomeWave shows 75 deg C. If I touch HomeWave, I get warnings from Prowl, and...
Open your iPhone’s settings screen, and scroll down. You’ll find HomeWave amongst the apps listed here. This is where the app preferences live, and where you can set the temperature unit to Fahrenheit.
When warnings (or other ALERTS, vs. "badges" or "banners" on the iPhone) come in, HomeWave shoots back to the Home screen. That's a pain if you're in the middle of something & an email comes in.
Another bug, I will look into this.
If I try to select an area with a "1x2" block with two "1x1" blocks next to it, I can't. I have to first split the 1x2.
That is per design. Someone else mentioned this, and in principle the app should allow you to select an area of mixed sized controls, as long as the selected area is rectangular. This is on the list to change.
If I add a "No control" empty space or label, I can't format it. No size, color, background, etc.
Correct, you can only set the label text. The upcoming v1.2 release will have some more options for formatting controls.
It seems to take about 5 seconds from the time I send a command via the MIOS web interface on my computer until it updates in HomeWave. Not good, not bad.
That is the nature of apps like these. Changes are not instantly pushed to the app, instead, Vera is polled every 5 to 10 secs to report changes.
It'd be nice to be able to change the format (colors, vertical alignment) of the elements on the Home Screen as you can on the other screens.
Coming in v1.2
