Anyone have any experience with using this with the Vera? Specifically, does UI4 work ok with it (presumably, status can only be gotten through polling), but does it work in a three-way configurations with a “dumb” mechanical switch as the manual seems to claim?
yup. Works fine. Use that with a ZRF113 that’s bound with a Harmony 890 so I can control a fluorescent light with a vera and the harmony. Before I finally got the ZRF113 (took ~6 months), I had a simple switch as a placeholder, and that worked fine. Only (minor) issue is that since the Harmony issues On/Off and not a toggle, pending on the state, I might have to push the “on” button to turn the light off.
