After upgrading to 1.7.830 I have been experiencing intermittent problems with motion zones remaining tripped in VERA when they are not actually tripped if I look at the DSC panel.
I’m using the EYEZ-ON EVL-3 Envisalink.
Is anyone else experiencing any issues or have any suggestions?
[quote=“Reliance, post:1, topic:193165”]After upgrading to 1.7.830 I have been experiencing intermittent problems with motion zones remaining tripped in VERA when they are not actually tripped if I look at the DSC panel.
Is anyone else experiencing any issues or have any suggestions?[/quote]
I’m still having this issue. Has anyone else seen similar behaviour and managed to fix it?
You might try creating a scene with the luup to resync with the alarm, and run it the next time you see a zone staying tripped to confirm. Note the bizarre data corruption issue on UI4 - so backup your Vera before you run it just in case… But no ill effects on UI5…
You might try creating a scene with the luup to resync with the alarm, and run it the next time you see a zone staying tripped to confirm. Note the bizarre data corruption issue on UI4 - so backup your Vera before you run it just in case… But no ill effects on UI5…[/quote]
Thanks for the workaround! I’m intrigued as to why this would only start occurring after a Vera firmware upgrade but I’ve followed the suggestion in the above threat and created a Scene which runs every 15 minutes to re-sync the alarm system states with the LUA code
I’m running Vera 3 Firmware 1.7.902, DSC Plugin Version 0.40 and it hasn’t crashed anything. I’ll have to wait and see if the intermittent problem is solved but so far so good!
