I have two MiniMotes which I have had for awhile. I used them with my VeraLite and they were migrated to my VeraPlus awhile ago. They work fine / perfectly as expected for normal operation. However I have a very interesting thing that tends to happen when my 2 year old son gets a hold of one of them. When he gets a hold of one, he starts pressing all of the buttons on it in a random sequence. This leave the MiniMote in a state where the red and blue light on it flash for roughly 30 seconds and the MiniMote is otherwise unresponsive. But the most interesting part is during this, EVERY light switch connected to my Vera turns on. Every switch, every time. He is able to accomplish this with only the four buttons that are exposed (he has not found the four buttons behind the sliding cover). Has anyone ever seen this before? Any idea how to stop that (other than the obvious keep the MiniMote out of my son’s hands)?
I don’t have one, but the guide says holding the top two buttons down is All On, holding the bottom two is All Off. Maybe there is a setting you can change to disable that?
Well…I never even thought to look at the manual…thank you for pointing that out. I would like to disable that feature if anyone knows how to do that.
