[size=14pt]Version 3.2 Released[/size]
I have created a plugin for Pentair Intellitouch/Easytouch that interfaces with the PC100 Autelis device for Pentair.
The plugin can currently control and report the following features of your pool. Please verify the version that you require v2.0 is for Vera firmwares > 7.05 and v1.0 is for prior firmwares.
[ul][li]Circuits[/li]
[li]Features[/li]
[li]Pool/Spa/Air Temperature[/li]
[li]Solar Sensor[/li]
[li]Pool Heat[/li]
[li]Spa Heat[/li]
[li]Heat Setpoints and Preferences[/li]
[li]Intellibrite Colors and Themes[/li]
[li]Intellichlor[/li]
[li]Intelliflo VS/VF Pumps[/li][/ul]
Release Version 3.2 - 07/23/2018
Users who are using the most recent version of UI7 should download and install this version. You do not need to uninstall the prior version simply copy the files onto your Vera as described in the installation guide. Then reload the Luup engine. After the Luup engine has had some time to reload, refresh your browser.
[ul][li]Fixed issues introduced with fw 7.0.27+.[/li][/ul]
Release Version 3.1 (fw Versions for 7.05+ only) - 09/20/2017
[ul][li]Added function to re-connect if Autelis is busy and the connection is rejected. Previously, the plugin would stop polling if it received a busy message.[/li]
[li]Updated chlorinator panel to use spinner control.[/li][/ul]
Release Version 3.0 (fw Versions for 7.05+ only) - 05/19/2017
[ul][li]Fixed issues related to connection errors if the personality board is busy when an update to the status is requested.[/li]
[li]Combined the Features and Circuits tabs into one.[/li]
[li]Added alternate egg timer for superchlorinate or shock cycles for Intellichlor. Use either Native Pentair or Plugin Enhanced.[/li]
[li]Added the ability to reboot Autelis from the plugin panel.[/li]
[li]Added Color Swim and Color Set options to Intellibrite panel[/li]
[li]Fixed icon indicator on heaters so that when heating with solar they are green and when heating with a gas/elec heater they are red.[/li]
[li]Added the Mode indicator to the main plugin panel so you can see which mode the Personality board is in (Service, Auto, Timeout… etc)[/li]
[li]Optimized pump status so it performs more intelligent polling during equipment transitions.[/li][/ul]
Release Version 2.0 (fw Versions for 7.05+ only) - 04/05/2015
[ul][li]Fixed issues related to dashboard controls created by changes to the way 7.05 positions controls[/li]
[li]Added color representation to temperature changes[/li]
[li]Rearranged Intellibrite panel to group themes and lighting controls[/li]
[li]Fixed salt level reporting for Intellichlor. Previously, this was reporting in resistance units. It now reports in ppm as described by your Pentair equipment.[/li][/ul]
Release Version 1.0 (fw Versions prior to 7.05) - 03/06/2015
[ul][li]Added icon state changes when device is on/of[/li]
[li]Fixed panel text location[/li][/ul]
Beta Version .92 - 02/02/2015
[ul][li]Support Variable Flow Pumps[/li]
[li]Superchlorinate options for SWG[/li]
[li]Pool/Spa chlorinator power setpoints[/li]
[li]Enhanced Simulation Mode[/li]
[li]Trigger, event, and notification support for all settings/states on child devices[/li]
[li]Tooltips to guide you through configuration[/li][/ul]
Beta Version .91 - 01-23-2015
[ul][li]Support Variable Speed Pumps[/li]
[li]Intellichlor IC 20/40/60 Support[/li]
[li]Polling Functions[/li][/ul]
Is anyone interested in controlling/managing their pool with Vera? New versions will be posted here.
From now on I will place the latest release here. The documentation can be found below
[ul][li]Installation Guide – [url=http://forum.micasaverde.com/index.php/topic,30275.msg217728.html#msg217728]http://forum.micasaverde.com/index.php/topic,30275.msg217728.html#msg217728[/url][/li]
[li]Configuration Guides - [url=http://forum.micasaverde.com/index.php/topic,30275.msg217729.html#msg217729]http://forum.micasaverde.com/index.php/topic,30275.msg217729.html#msg217729[/url][/li][/ul]
