Has anyone connected a Hormann Supramatic 4 to a Vera/Ezlo controller? I can’t figure out if the Homematic ip-gateway will give any control through bisecur or bluesecur? Just don’t suggest Homey controller! ![]()
I have two hormann controllers and I just attached a fibaro relay to each one using the external button input connection. I had to add an external sensor in order to get the status. I’m not sure if the supramatic has a know ip, I have the plain version.
Plain relay or roller shutter? What do you use as an external sensor? ![]()
I have a reed sensor connected to a fibaro dual relay 2, so 12v. One switch is to open, one to handle the sensor.
Search for Hormann Shelly and you’ll find the same schematics.
