Seems like if I post the issue in appropriate forums, I never get a response.
So, not apologizing, here are the two questions:
- Is there a way to hook up Cyber-Rain Cloud version to MCV Vera2?
- Is there a way to hook up ADT Pulse Security System to MCV2?
- Is there a way to hook up HAI OmniProII to Vera2?
If the answers are yes to anyone, kindly do post a detail link.
Many Thanx in Advance. Hope someone will answer
OK, I am convinced that there is NO SUPPORT here or anywhere else.
I am returning BOTH my Vera 2s and off to a better controller that provides support… Perhaps Homeseer…
This is ridiculous…and MCV expects to be a LEADER? Leader in what I ask?
@techyman99,
You’ve asked whether Vera will integrate with a number of very specific CLOSED systems, ones that have no openly published API’s.
Typically in these cases, the answer is going to be “no”… integration is not possible, at least not in the way that you’d want, or without you doing the lifting to determine how (as folks are doing with some of the Alarm Systems).
Think of it as asking whether a Audi motor will work in a BMW… it’s unlikely that type of integration would work as expected, albeit potentially possible for someone with Technical skills.
Questions for you:
a) Have you asked these vendors what Integration options they’ve exposed?
b) Did anything indicate these products were integrated prior to buying Vera?
c) Do you have the technical skills to work it out for yourself (like the Honeywell/Ademco folks are doing in other threads)
The ADT integration thread you posted to previously has been used by a bunch of spammers/link promoters/sales folks for that system. I have no expectations they’ll ever answer the original question… it’s likely that’s not in their best interests, so a number of us simply ignore that thread
With an openly published API, well documented functional behaviours, and someone keen to script the integration you’ll find that a large number of things are possible with Vera…
NOTE: This is not a support forum, most people here (like me) are simply HA enthusiasts/users that are willing to help. There are no guarantees of a response, and certainly no SLA’s. If you want support, on an item that the product advertises functionality for, your best bet is to call MCV’s support line…
