Insteon I/O Linc Low Voltage Contact Closure Model: 2450
I’m using the hardware configuration above to control an electrified mortice lock. When I login, the Insteon Contact Closure Model: 2450 appears in the “Light” catagory in my device list. I’d prefer for it to appear in the “Security” category. And on Vera Mobile, I’d like to see it under the “Lock” tab in the security category. Please advise.
That device is just a relay, do it’s on/off light a like switch.
You would have to reimplement it as a lock decide type to get it to show up in the other category.
I’d suggest you install the Garage Door Plugin instead.
That will take the sensor from the IOLinc, the Relay, and “fuse” them into a single device that looks like a lock.
Unlocking it opens the door, locking it closes the door.
Thanks very very much for your assistance. Forgive my ignorance. I’m great with mechanical stuff, but anything to do with systems integration and programming is my failure. I installed the Garage Door Plugin and couldn’t quite make it all work. Loads of errors etc. So, I uninstalled the garage door plugin and went back to my previous configuration using a scene and trigger. This set up works perfectly for me. With the one exception, that my relay shows up under “Lights”, as opposed to where I’d like it to show up, “Locks”.
QUESTIONS:
Do you see any way to keep the current set up, but to get the IO Linc Relay to show up under “Locks”?
Also, why do I see a device called “IOLinc Sensor”? Does it serve any purpose for me, can I make it go away? If yes, how?
You can’t make the relay appear under the locks tab, since it isn’t a lock. Unfortunately with Vera, you can’t tell them where to go.
As for the IOLinc sensor, I figured you were using that. This is the sensor built into the IOLinc. You can attach a magnetic reed switch (an alarm sensor) to the IOLinc, and it will tell you if the door is opened or closed.
For the Garage Door Plugin to work, you need:
a relay (in your case, the IOLinc Relay)
a sensor (in your case, you have one in the IOLinc sensor)
Your prompt responses are very much appreciated. Thanks very much.
When I go to my list of devices, then click on the wrench in the upper right corner of the IOLink Relay, then click on advanced, in the field titled “Device Type” I see “urn:schemas-upnp-org:device:BinaryLight:1”. Does the data in that field have anything to do with with device showing up under “Lights”? I was wondering if I edited that field in some way, could I get the device to show up under “Locks”?
Thanks for your explanation on what the sense does. As I have no use for the sensor, can I delete that device, or would that also delete the IOLink Relay?
[quote=“jonr, post:7, topic:178151”]Your prompt responses are very much appreciated. Thanks very much.
When I go to my list of devices, then click on the wrench in the upper right corner of the IOLink Relay, then click on advanced, in the field titled “Device Type” I see “urn:schemas-upnp-org:device:BinaryLight:1”. Does the data in that field have anything to do with with device showing up under “Lights”? I was wondering if I edited that field in some way, could I get the device to show up under “Locks”?[/quote]
Changing the device type won’t work. Vera will expect the device to have handlers for that device type, which that sort of device doesn’t have.
[quote=“jonr, post:7, topic:178151”]- Thanks for your explanation on what the sense does. As I have no use for the sensor, can I delete that device, or would that also delete the IOLink Relay?[/quote]I think it will be re-created the next time LUUP is restarted, but I am not sure. I don’t think it can be deleted outright.
I created a room called “Unused” and put everything in there that I don’t need direct access to (sensors, plugin parents, scene controllers, FanLincs where there are no lights, KPLs with no loads attached, etc).
