Thanks for the update. I uploaded the new icon to www/cmh/skins/default/icons and replaced the older icon, will the master device update its image by itself? I know its a small thing but just was curious .
Edit: The master device did change the icon to the new one itself
Donât worry about the icons or chime sound file. The plugin deals with those on its own. It has actually undone what you did and done it its way by now.
It takes at least a hard refresh for the new icon to show. It may take more than that, as browser caching is a really tricky business sometimes. After a hard refresh, if it still doesnât show, right-click on the old icon, choose âOpen image in new tabâ, then hard refresh that tab and it should update. Close that tab, and hard refresh the Vera UI tab again.
Or just wait, and eventually your browser will figure it out.
A small bug ive noticed is all my favourites arenât showing up in the drop down menu for song favourites
Im updated to latest version
Hi!
I have 3 Sonos. Each and every one shows: âOffline; waiting for proxyâŠâ and âCanât Detect Deviceâ
since I updated to the latest version. The previous version worked ok. Any thoughts why?
Thank you @rigpapa! Your dedication and support is much appreciated for this and all other plugins!
@Fanan, if the message does not go away after about a minute, please go the master device and turn on âpluginâ debug (only), then reload Luup, wait 60 seconds, and then run this in the âTest Luup Codeâ tool (copy-paste):
for v=1,16 do luup.log(string.rep("X",128),50) end
os.execute( "gzip -c /var/log/cmh/LuaUPnP.log >/tmp/log.gz" )
os.execute( "ln -sf /tmp/log.gz /www/" )
Then download the log file by requesting in a browser: http://your-vera-ip/log.gz
This should download a large-ish binary (compressed) file. PM me here and drag that file into the message.
**It appears some of us (in the US?) are having problems reading and posting to the forums. Iâm seeing an expired certificate message, and posting is hit-ot-miss for me.
Forum is very slow for me too, Iâm in Canada
Also very slow here in Holland
Back on line this morning. A couple of people I chat with off-line had similar issues. We were seeing an old expired certificate for the site. In one case, there was a 3/17/2020 expiration, and another had a 12/18/2019 expiration! Today the cert is showing 3/6/2022 expiration and all is working well. Back to business!
Yup, seems to to back, but I still see the December 18, 2019 certificate expiration.
Hi Patrick,
Run into a snag installing the plugin. My blue status bar shows âSonos: Duplicate master deviceâ.
Version is
2.0develop-20077.1800.
What other info do you need?
Thanks,
Roger
I think the message is pretty clear, so the resolution should be no surprise as well. Somehow you created two master devices. If you are upgrading from a previous 2.x release, you may have done steps 11-13; after the initial installation of 2.x, any upgrades to newer spins are only steps 4-10 (and 14).
Find the two master devices and go into their Advanced > Params and not their device numbers. Delete the one with the higher device number, and reload Luup.
Sorry for the stupid question. I didnât see the engine that was created in the âNo Roomâ and was headed out the door so didnât have much time to investigate.
Just a note for future if it helps;
I just noticed 2 streams playing with Alexa on Sonos at the same time. I verbally initiated a song. It started playing immediately but with low volume. A second later Alexa confirmed the song with title and artist in loud volume while music continued in background. When she finished her prompt, the volume rose to the initiated level.
With Alexa integrated into Sonos, Iâm sure it can do some awesome tricks.
The current version of Sonos 2.0 is now 20081.1005
- Tested and working on openLuup. TTS requires special configuration, so please see the README file for instructions.
- Vera3/Lite are not currently supported for Azure TTS due to limitations in Veraâs LuaSec libraries (not an uncommon problem these days). I am investigating workarounds but if it doesnât jump to life, Iâm not going to spend any more time on it, as these platforms are off support with Vera anyway.
- The
Say
andAlert
actions now accept parameterUnMute
(boolean 0 or 1, default 1) to unmute target zones before playing the speech/alert. - The TTS cache now prunes itself. By default, it prunes speech files older than 90 days since last use (so if you use them, they resist pruning). You can change the age-out by setting
TTSCacheMaxAge
to the desired number of days. Setting it to 0 disables cache pruning, but you will then need to manage disk usage yourself.
My expectation now is that this is the last development release/alpha before beta. I am shooting for release to the App Marketplace around 4/12.
Ive noticed the volume on my sonosâs blast when I start music. Iâm not sure if its related to TTS or not.
What is the correct setting to have the music play volume and Alexa volume return to their previous levels after TTS has spoken?
There is only one volume setting that I am aware of, and it is restored when TTS completes.
FWIW, bear in mind that Alexa likes to be told âVolume Nâ (where N=1-10), whereas Sonos â and by extension, any Sonos plug-in â expects values N=0-100. So make sure your Alexa-enabled Sonos device isnât getting the wrong message somewhere along the line.
I use Reactor to reset my Sonos volume daily, and Alexa routines to do the same with my Alexa devices nightly. Because I hate loud things!
To be clear, I view anything the built-in Alexa integration for Sonos does to be as relevant to Sonos as an Echo Dot sitting across the room from the Sonos. Unless the Sonos itself notifies the plugin of changes the Alexa might be making, there is no way for it to know what Alexa is doing to the Sonos, or be able to undo it. The fact that built-in Alexa can reduce the volume of Sonosâ playback so Alexa can play its audio over that, for example, tells me only that Alexa has an input to the Sonosâ audio mixer hardware (as expectedâshared speakers), and itâs quite possible (likely, based on what weâre seeing, in fact) that the volume reduction is done in the electronics without any changes in Sonos parameters or even the awareness of the Sonos CPU at all.
Regardless, I donât own any Alexa-integrated Sonos devices, and I wonât be buying any in the foreseeable future. So far, the community has not demonstrated that there is adequate interest in this plugin to support any additional investment.
