Hi there,
Did someone manage to install a VNC server on the Vera-3.
I’m thinking of installing TightVNC.
Cu Wim.
Hi there,
Cu Wim.
What would be the purpose? Vera does not have any type of x11 software or gui running on the box. It only has a web server to host UI5.
VNC provides an interface to a local “desktop” - Vera only has a web server interface, so at best you won’t see anything using VNC that you couldn’t do with a telnet / SCP type connection (using WinSCP / PuTTY under Windoze).
Chris
OK if there is no X-Windows or compatible then it is rediculous indeed.
Thanks,
Wim
