[quote=“davidlee, post:1, topic:166952”]It looks like the directory 海外の発酵食品の特徴と歴史 no longer exists.
Anyone know how to get around this to install the NTP client?[/quote]
Otherwise comment out the line entirely. You’ll still get the basic Openwrt packages which should include the NTP client, though you may miss the GUI to configure it.
/etc/opkg.conf is the file that lists the sources, I think.
Thanks for the reply, go me pointed in the right direction.
What an adventure…
Did the changes, selected install from web interface, install seemed to go through, but never installed.
SSH into vera.
root@HomeControl:/etc/config# ipkg install ntpclient
Installing ntpclient (2007_365-1) to root…
Nothing to be done
An error ocurred, return value: 28.
Collected errors:
Only have 0 available blocks on filesystem /, pkg ntpclient needs 52
root@HomeControl:/etc# df -h
Filesystem Size Used Available Use% Mounted on
tmpfs 14.9M 1.0M 13.9M 7% /tmp
/dev/mtdblock/4 9.9M 860.0k 9.0M 9% /jffs
mini_fo:/jffs 5.3M 5.3M 0 100% /
Ok, no space available where ipkg is trying to install.
