Hi, I’m currently using a VeraPlus with UI7 (latest code) with plugin version .24 talking to a wink hub version 3.5.20-0-…
Despite the vera learning about many devices… The application never gets out of status “Initializing child devices…” and as such. I can’t turn off or on Lights on the wink or activate any other device controlled by the wink…
From the logs one line of particular interest is:
01 03/25/17 10:44:14.760 LuaInterface::CallFunction_Startup-1 device 487 function Wink_Connect_Startup failed [string “-- Wink_Connect 0.24…”]:9341: attempt to concatenate global ‘vID’ (a nil value) <0x76621520>
but I dont really understand what it
s trying to tell me… here is the context around this message. Let me know if I should provide more log information to help diagnose…
02 03/25/17 10:44:14.585 luup_log:487: (Wink_Connect::HUB_DEVICES::createVeraDeviceTable): Creating Vera device table. <0x76621520>
02 03/25/17 10:44:14.603 luup_log:487: (Wink_Connect::configureWinkDevices): Built Vera device list. <0x76621520>
06 03/25/17 10:44:14.661 Device_Variable::m_szValue_set device: 487 service: urn:micasaverde-com:serviceId:Wink_Hub1 variable: Hub_Status was: Configuring devices now: Configured… #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x76621520>
02 03/25/17 10:44:14.662 luup_log:487: (Wink_Connect::findChildDevices): Processing child devices. <0x76621520>
02 03/25/17 10:44:14.718 luup_log:487: (Wink_Connect::findChildDevices): Completed processing child devices. <0x76621520>
02 03/25/17 10:44:14.718 luup_log:487: (Wink_Connect::initializeChildDevices): Initializing child devices. <0x76621520>
06 03/25/17 10:44:14.719 Device_Variable::m_szValue_set device: 487 service: urn:micasaverde-com:serviceId:Wink_Hub1 variable: Hub_Status was: Configured… now: Initializing child devices… #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x76621520>
01 03/25/17 10:44:14.759 LuaInterface::CallFunction_Startup device 487 function Wink_Connect_Startup took 22 seconds <0x76621520>
01 03/25/17 10:44:14.760 LuImplementation::StartLua running startup code for 487 I_Wink_Hub1.xml failed <0x76621520>
01 03/25/17 10:44:25.487 luup_device_supports_service interface 0x15e6310 args 2 <0x73863520>
01 03/25/17 10:44:25.487 GetLuaInterface can’t find device type: 3/0x1707580 str: 8 <0x73863520>
06 03/25/17 10:44:25.873 Device_Variable::m_szValue_set device: 477 service: urn:micasaverde-com:serviceId:EEM-Plugin1 variable: TSDeviceList was: 406;429;487;438 now: 406;429;487;438 #hooks: 0 upnp: 0 skip: 0 v:0x1232bc0/NONE duplicate:1 <0x73863520>
Any help you can provide to help understand where things are going wrong would help. Let me know if you need more info.
