Hello,
Little intro:
I have 2 VeraPlus devices. The first one is the ‘steady live’ unit. The second one is a replaced unit for a bricked VeraPlus, I use the second one only for some testing. After some years I want a stable soloution. Bridging 2 VeraPlus devices? Hmmm. Don’t like the idea. The live VeraPlus is working with 168 devices. ( Zwave devices, some virtual, some added trough Hue, Powermax, Netatmo, Opentherm Gateway). This is why I have many problems with the memory. Stability issues and update problems (not enough space left) And so on… After reading some things about OpenLuup I was willing to gif it a try. I bought the third Raspberry Pi3+ and installed Openluup. Thank you for Openluup and AltUI. A great way to leave the memory troubles behind!! (that’s what I think, and hope). Before deleting something from the VeraPlus devices and let them act as a Z-wave bridge, I want to get to know more about AltUI and the use off OpenLuup. The system reacts in a great way! For now I just struggle with some plugin installation problems:
END Intro
I have a some more Raspberry Pi3’s working, and one is in use for Grafana. I would like to delete the Veraflux plugin from the Veraplus, so I read about the possibility to use the build-in option in Openluup to push data trought Influx. I have added 2 lines to the startup Lua.
luup.attr_set ("openLuup.Databases.Influx", "192.168.2.158:8086")
luup.attr_set ("openLuup.Historian.Directory","home/pi/history/")
When I restart the unit and look at a device-variable I can only choose: Emoncms, Vera@IP,IFTTT and Thingspeak.
I can’t get Influx show up.
When I read the startup log I found some info:
'2019-05-04 08:46:43.417 openLuup.init:: running _openLuup_STARTUP_
2019-05-04 08:46:43.418 openLuup.context_switch:: ERROR: [string "_openLuup_STARTUP_"]:4: module 'InfluxDBRelay' not found:
no field package.preload['InfluxDBRelay']
no file './InfluxDBRelay.lua'
no file '/usr/local/share/lua/5.1/InfluxDBRelay.lua'
no file '/usr/local/share/lua/5.1/InfluxDBRelay/init.lua'
no file '/usr/local/lib/lua/5.1/InfluxDBRelay.lua'
no file '/usr/local/lib/lua/5.1/InfluxDBRelay/init.lua'
no file '/usr/share/lua/5.1/InfluxDBRelay.lua'
no file '/usr/share/lua/5.1/InfluxDBRelay/init.lua'
no file '../cmh-lu/InfluxDBRelay.lua'
no file 'files/InfluxDBRelay.lua'
no file 'openLuup/InfluxDBRelay.lua'
no file './InfluxDBRelay.so'
no file '/usr/local/lib/lua/5.1/InfluxDBRelay.so'
no file '/usr/lib/arm-linux-gnueabihf/lua/5.1/InfluxDBRelay.so'
no file '/usr/lib/lua/5.1/InfluxDBRelay.so'
no file '/usr/local/lib/lua/5.1/loadall.so'
2019-05-04 08:46:43.418 _openLuup_STARTUP_:: ERROR: [string "_openLuup_STARTUP_"]:4: module 'InfluxDBRelay' not found:
2019-05-04 08:46:43.418 openLuup.init:: init phase completed
But when I look into the directory’s I cant find those folders.
It looks like I miss the InfluxDBRelay, or it can be found on a another place inside te Raspberry Pi.
Can someone give me something to put me in the right direction?
