incorrect version of Smartphone Web Interface?
I have installed the smartphone webinterface today via the Mios Marketplace.
After (seemingly correct) install i get this info from the plugin:
Plugin: 6 Title: Smartphone Web Interface Version: 0.65
However the plugin version in the Mios Marketplace stated version:
Author: Mi Casa Verde For: Mi Casa Verde Model: many Using: internet License: GPL3 Version: 1.019 Price: free
Anyone any idea what the mismatch is and how to obtain the correct version?
I understand i have to login through MO, so i will try this version and see whats up with it.
Will post back later with results.
Henk
UPDATE
My findings after using the Smartphone Web Interface:
  1. It still uses the UI2 layout. i do hope this gets changed when UI5 is released to, all in favour of unified control look/feel.
  2. I noticed a bug (not sure if its logged already) when logging in without selecting a gui (text based/graphical ui) but simply hitting “enter” where the error message “this plugin is not installed on your device” is shown.
This might be due to default faalback to the textbased GUI that i have not installed.
Workaround could be not to accept “enter” but force the user to push one of the available buttons to continue.
Anyone using a newer version of the plugin with different/better results?
I have also noticed that the version info does not match! I have also found that although my security system shows up the indicators for on/off do not work and that selecting on does nothing! ???
@Henk: I have the same mismatch of version numbers you’ve reported. I purchased my Vera2 (.1245) in June of this year and installed the smartphone link then. Since I started with UI4, I knew the phone IF looked different, but didn’t realize it looks like UI2. My switches, thermostat, and 3-in1 all seem to work ok over the phone, but the kwikset deadbolt doesn’t status doesn’t show lock or unlock initiall. After a few minutes and a few refreshes on the phone, the deadbolt status does show ok.
