I’ve had a Vera II (we’ll call it Master) working fine for months. A couple weeks ago I bought a second Vera (Slave) for my detached garage. I have a z-wave Kwikset lock in the garage. I’ve followed the instructions for importing (add device, etc) but the Master Vera can’t see the Slave Vera. However, if I try to add the Master Vera to the Slave Vera, the Slave does see the Master - but all my scenes are on the Master.
My set up is as follows: Apple Airport network in the house. The Master Vera is connected to the main airport with Ethernet cable. I’ve set up the Slave Vera through the “Net & WiFi” tab by checking “Through a wifi access point…” I put in the airport network name/password. It must have worked because the main airport IP address now shows up on the Slave Vera Net & WiFi tab. HOWEVER, the WiFi light on the Slave Vera is not lit! And I cannot see the Slave Vera on my list of networks on my computer - only the Master Vera (I don’t know if that’s important or not).
Any help would be greatly appreciated.
