The 2.0 release is awesome! Just what i wanted finally…have gone PRO! Thanks guys.
One tile i thought would be cool is to “start a hangout” - for video calling. Or take it a step further and invoke the hangout with a named person. Eg: Call Mum
With respect to exporting settings, how about allowing a “master” tablet to push new configs to your linked wall mounted tablets? So you can edit the settings on your master, save the changes and the wall mounted tablet you have edited will get the update.
Also, add to all… So when you add a new device you can say which wall mounted tablets receive it…
Any news on getting the camera detection wakeup working with Nexus7 ?
@ImperiHome
Please consider performing all refreshes and updates in the background. It is very annoying to open the app and then wait before being able to turn something on or off.
Really the best Android remote app for Vera! I upgraded to the pro! WindSensor works perfect Very good support, when requesting a new device to be supported.
Two suggestions
1- perform all refreshes in the background
2- report errors like the way Vera mobile app and Authomation does. eg, report if network is not connected and command cannot be performed correctly
[quote=“ImperiHome, post:26, topic:177366”]Big thanks to everyone for your feedbacks.
We’ve written your suggestions, and will do our best to integrate them in the future
Just wanted to notify that the 2.0.8 update including some of your requests : edit mode for easy re-arranging widgets, and a new white/light theme.
Great app! Unfortunately my Fortrezz WWA-01 sensors do not show up. Can you add this device.
None of my cameras work either, I’m using the plugin “VistaCam PT&HD IP Cameras”. What camera plugin made your cameras work within Vera? I can’t use the external “IP Camera” because I’m on satellite Internet and it does not allow inbound connections so I’m forced to use the Vera connection.
Edit: 4 of 5 cameras are working, just took a little time to load (I blame it on the Satellite latency delay). My Foscam FI9821W HD is not supported.
Just installed the basic version. Tried to make a Composite Security widget for all my z-wave locks, it wouldn’t allow it. Does this widget only accept door/window sensors?
You’re right : composite security widget currently only works with “trippable” security sensors such as door/window sensors, motion sensors, smoke sensors, flood sensors…
Would you need to have a composite ‘lock’ widget to see you locks statuses ? and/or being able to activate all of them at the same time ?
Best,[/quote]
Exactly. Think about it, the same you would want to see a global status if any of your windows were open, why wouldn’t you want to see if any of your doors were unlocked? Just seems sensible.
Hi Imperihome - Can you add further support for Garage door plugin/device
Basically, Allow to add to composite security widget
“pulse” button to open/close
Nicer icon than padlock
[quote=“gregl, post:34, topic:177366”]Hi Imperihome - Can you add further support for Garage door plugin/device
Cheers,
Greg[/quote]
One option is to use pictures in the background, and no icon. For my scenes, I took a picture of my garage door, and used this instead of an icon. Looks great, and more specific to your system.
