IF Condition to run in a SCENE
Gang, i am new to Vera and zwave. I have Vera 3 and several modules. I created a scene called Sunset Lights which basically turn some lights on triggered by the Day/Night plug in. BUT i dont want this Scene to run IF my status is away . I can read the away status from my THermostat (NEST) … Any tip how i change this scene to run ONLY when i am Home ?
I highly recommend that you use the search function. Your question has been asked in similar fashion and there are many answers /the solutions to do this. One example is to use the PLEG plugin. If you want to use lua / luup code, there should be many examples showing you have to get the status and only act upon it when the condition is met. A good start is to look in this subforum.
  • Garrett
