Please check out iBlinds on Kickstarter. iBlinds work with any 2" horizontal window blinds. We have performed test with several different Z-Wave Controllers including the a Vera Edge. The iBlind tilt motor pairs with the Z-Wave network as a light dimmer. On/Off = Open/Close blinds, you can also use the value slider to control the tilt angle of the blinds.
Also check out the testing video on the campaign page, shows full 180 tilt.
[quote=“iblinds”]Please check out iBlinds on Kickstarter. iBlinds work with any 2" horizontal window blinds. We have performed test with several different Z-Wave Controllers including the a Vera Edge. The iBlind tilt motor pairs with the Z-Wave network as a light dimmer. On/Off = Open/Close blinds, you can also use the value slider to control the tilt angle of the blinds.
Thanks[/quote]
Wish your project had been funded… I cobbled together something similar with a cheap servo, shaft coupler, custom arduino board and that mysensors stuff… Works, but yours is very polished!
I didn’t back the MOVE project because it is bluetooth and I’ have preferred ZWave or Wifi… but if it turns out to work well with Wink I’ll be buying these
