I’m using a Veralite with UI7 and a Powerlinc modem.
I’ve wired two IOlincs to control two garage doors. Using the local “set” buttons on each IOlinc to change their configurations, I set each to relay mode “A” which sets the relay to respond to “on” or “off”, but not both. I found this unsuitable due to the latency from having to send multiple “on” and “off” commands, so I changed it to mode “B”, which is supposed to respond to either command.
At least I thought I did.
The only modes Vera seems to recognize are latching and mode “A”.
To confirm it wasn’t my configurations, I downloaded Houselinc to my PC and checked their settings. I can successfully read and write the configurations from Houselinc. I can also set one of my Switchlinc light switches to send both on and off commands to an Iolinc and have it respond appropriately.
When I go back to Vera, same old story. >:(
It should also be worth noting that I can disconnect my pc from the modem and the switchlinc / iolinc test configuration stays intact.
Is anyone using an IOlinc in relay mode B? with the same setup as mine? If so, how did you get the vera to recognize this configuration?
