- I have a Router with WIFI - How to add MCV so it would connect with Wi-fi?
- The point is, I don’t want to hard wire to my router.
Thank you.
Thank you.
Thanks. Got it working. It took a while - needed a reboot of my router MCV etc,
I think it is pretty simple as you just have to plug it in to the modem or a switch or a router to give in internet access. I think it is best to use this wired connection as this ensures good data transmission through cables.
But over a wifi network, you can have it go to a wifi client mode so that it could connect through that and not look for something over the wired connection. Follow the link so that you could get answers should problems arise.
