[quote=“randya, post:57, topic:199599”]sooooooo, quick question…
if you guys are using Home Assistant, which I just recently started using (this week) and LOVE IT coming from just using UI7… AND… you guys also have an AEOTEC ZStick which I am led to believe has more the zwave protocol than most other controllers (including Vera), why are you still using Vera?
I was planning on using Vera as the zwave bridge from HA, since I don’t have a Z stick. But it is less than $50 and doesn’t phone home?? hmmm, very appealing to me to drop Vera all together. But so that I don’t rush into anything blindly, I thought I would ask the above question
I assume because you guys want redundancy (secondary controllers)… or are doing a full transition but are still in the process… Please, share “why vera?” in today’s environment when you already have HA and Z stick
(this is meant to be a serious question and in no means a bashing of Vera. I have used Vera for ~10 years and am actually sad to have to go out and find other solutions)[/quote]
Shamelessly linking my other thread where I explain why I am keeping the vera. If unlike me you are willing restart then it would make sense to me to do away with it.
http://forum.micasaverde.com/index.php/topic,101078.0.html
[quote=“zedrally, post:58, topic:199599”]^^^ Not sure you got the idea that the AEOTEC has more protocols?
If you use a UZB with the latest SDK, then you have all the protocols (Command Classes) that are currently available, however some may not be supported by HA software.
I believe (but stand open to correction) that the only HA software that supports the most Command Classes is Z-Way.
I pretty sure that I’ve left a lot of gaps here but it’s a starting point for a discussion.[/quote]
If for anything the Aeotec z-stick would support less. It’s SDK version is only 3.95 vs. 6.1 for the vera.
