Now, I updated version 1.1.1186 with http://micasaverde.com/vera2?beta=1
VERA is not accessible when connected to my routeur ADSL
MIOS does not recognize VERA (I didn’t detect a unit on your home network.)
[i]http://sta1.mios.com/locator_json.php[/i]
{“SerialNumber “:[{” unités”: “”, “version du micrologiciel”: “1.0.616”, “ipAddress”:
“192.168.0.12”, “utilisateurs”: [“chrifabre”], “forwardServers”: [ {“hostname”:
"ra1.findvera.com», «primaires»: }]}]} vrai
Location Change
ERROR: Unable to connect to server.
Please check your internet connection and try again.
Advenced Tech Support
Tech support full access disabled
Advenced Firmware :
<< UNDEFINED Download Server. Using predefined.
Testing connection to: download.mios.com … OK
You are running the latest version: 1.1.1186 .>>
Advenced Net Wifi
<< Internet access is ok.
How does MiOS connect to the Internet?
Through another gateway on my network. MiOS is a switch
What Network Connection Type do you have?
Static IP
IP address: 192.168.0.12
Subnet mask: 255.255.255.0
Gateway 192.168.0.254
DNS 212.27.40.241 >>
TroubleShoot Network
=== IP Configuration ===
br-lan Link encap:Ethernet HWaddr 90:E6:BA:43:6D:A6
inet addr:192.168.81.1 Bcast:192.168.81.255 Mask:255.255.255.0
br-lan:0 Link encap:Ethernet HWaddr 90:E6:BA:43:6D:A6
inet addr:192.168.0.12 Bcast:192.168.0.255 Mask:255.255.255.0
eth0 Link encap:Ethernet HWaddr 90:E6:BA:43:6D:A6
eth0.0 Link encap:Ethernet HWaddr 90:E6:BA:43:6D:A6
inet addr:127.0.0.1 Mask:255.0.0.0
wl0 Link encap:Ethernet HWaddr 90:E6:BA:43:6D:A6
Interrupt:2 Base address:0x5000
External IP: 88.173.202.219
=== Testing Gateway: 192.168.0.254 ===
GATEWAY:OK
=== Testing DnsServer: 208.67.222.222 ===
DNSSERVER1:OK
=== Testing DnsServer: 212.27.40.241 ===
DNSSERVER2:OK
=== Testing DnsServer: 212.27.40.240 ===
DNSSERVER3:OK
DNSSERVER4:OK
DNSSERVER5:OK
DNSSERVER6:OK
=== Testing External Servers ===
GOOGLE.COM:OK
sta1.mios.com:OK
evt1.mios.com:OK
ts1.mios.com TUNNEL CONN:OK
fwd1.mios.com:OK
fwd1.mios.com TUNNEL CONN:OK
SSH_TUNNELS:NONE
== DONE ==
Power Light Indicator
the power light is on solid
Wan light is on
Z-Wave Dongle is into USB and light on
remotely on a PC of a friend, I can log in
using the address <http://88.173.202.219:80>
the database Mios is not updated
she returns the version 1.0.616 that I installed the latest version 1.1.1186
Cordialement
Christian FABRE
