hi
I’m new here on micasaverde’s site,
. my controller is the Vera lite. I’m having some start up problems whith the system, but I’m sure when it’s solved I’ll be happy whith my purcase.
I can control my plugins for light, noo problems there. But the Danfoss devices are not availeble ???
What to do ?
Allan
Denmark
Hi Allan, welcome to the forums!
Can you send me your user data? I don’t own a Danfoss device so I can’t really test, but if you send me the information, I can probably add support for it to Home Buddy. It would also help if you send me some screenshots of Vera’s UI so I can figure out what controls I need to show.
If you need help with getting your user data, please check my troubleshooting page:
Thanks,
rakstar
Fixed in the latest BETA build
I can see the Danfoss Living Connect, but the current set point - temperature- is no longer visible as it use to be in the initial version.
