I installed and setup the WOL add-in for Vera, this seems to work well and I can now wake any PC in my home from the Vera Web UI.
I would now like to be able to manually make them go back to sleep mode.
On my WHS server I have created some commands that can be run to make a certain PC go back to sleep. I am using the Windows tool PsShutdown from PSTools.
Command line to make a PC sleep
PsShutdown \PCName -u user -p password -d
Using PsShutdown works and when I run the command the PC goes back to sleep OK.
Can I run a .cmd or .exe file stored on my WHS from Vera ? Or run the command directly from Vera ? Which would probably be better.
Yes I saw those as options, However I would have to install a second TCP controller on the HTPC’s as I am already using the other TCP controller for other things. So I would rather not install the one from Kindel (MCE Controller) as well as VMC Controller.
So looking for other options to send commands from Vera
I wanted my computer to hibernate if I left the house or went to sleep.
The Wake-On-LAN plug-in and MCE Controller script was super easy! Works like a charm.
Very surprised at the instantaneous response.
