I am as dumb as I seem
Trying to take care of a few Z-Wave pains and one of them was a dead switch just outside the master bedroom…or so I thought. I guess I’ve gotten so used to switches dying on me I didn’t check the most obvious problem…is the bulb still good. So after a half hour of wires everywhere and head scratching it dawned on me…new bulb and TA-DA!
Now for the issue. Since replacing the bulb (and removing the switch from the wall) that switch says “Unable to get any information on”. Next step was to try to “Exclude” “Under Full Power” and it wouldn’t. I then just deleted it and re-added it "Under Full Power’ and it added it fine and even controlled it…once. After that it went back to “Unable to get any information on”. I went through all that one more time but this time I “Updated Neighbors” to the switch next to in (it’s in a double gang box) and that caused it to do it again. One last try, I did it all again and his time I just tried to assign it to a room and not try to control it, a few minutes later same message.
Now what?
Well that’s pretty damn funny. Always try the simplest thing first from now on. ;D I don’t know what to do about your issue though. Does the switch lose its pairing when it loses power? I know the locks and thermostats I have don’t.
