I have a scene set up to change the temperature in a section of our home if motion is detected. I have it set to chaneg the temperature to new setpoints and then after 30 minutes “go back to previous settings”. The scene works for changing the setpoints, but never returns to prior settings when no motion is detected. Any thoughts?
Well switched to just using ESM → Normal and back in the scene and that works, so I guess issue avoided, but still strange this does not work properly.
I have a similar problem. When I try to lower a thermostat setting and to restore it with the “Go back to previous settings” after a time delay, the thermostat does not get restored. If I instead instruct to set a new temperature when the timer expires, it works. The system must not read and save the initial setting correctly.
