We have just released the beta version of the plugin for HundredGraphs and looking for testers.
Previously you have to install the lua file yourself and that created a lot of confusion.
The plugin finds energy reporting devices by itself. You would only need to update the API KEY in Variables and change the reporting interval if desired.
The version 1.4 is published on Alt App store in ALTUI. Also a request to publish was submitted at the official store.
I installed the app thru the alt app store and put in my api key from the site…and nothing happened. The feed doesn’t show up.The device shows enabled on the vera devices page.
The next version should null that limitation, but for now this is what it is. Vera is kinda limited in how you can encode json, so if anything else than ASCII the json can come up corrupted
You can ignore “disabled” for now, it should switch itself to “enabled”, but! the most important part is “200”, it means it was processed by the backend.
It is still in beta stage, so I apologize for some hiccups
