Light sensors (status) are available under Status Labels… We don’t have a humidity status in the current version, but I can add one. I would like to get a copy of your configuration to make sure that I am getting the right info. Can you open a ticket on our ticket system (mention your username from here or something else so that I know its you) and then I can tell you what I need and you can send it to me… thanks
Power monitoring is also coming… expect to see this in the next version released (hopefully).
@Squareconnetjohn; I’m too using the power montior and have the app would love to see it added. Also will you be adding Fortess Leak Detector as a option as well to next verison?
