[quote=“sanderbaks, post:3, topic:199431”]Id Type Name Model SWVersion Reachable
5 Extended color light Tv lamp Philips LLC020 5.105.0.21169 true
From the Advanced Tab:
Device #26
Type: urn:schemas-upnp-org:device:DimmableRGBLight:1
JSON: D_DimmableRGBALTHue1.json[/quote]
I do not see problems in ALTHUE. in fact these screens shot that you show are displayed by UI7 from vera. it all depends on how well UI7 displayed devices of type Type: urn:schemas-upnp-org:device:DimmableRGBLight:1 and that is not under my control
it could be interesting to see how this same device is displayed in ALTUI for instance
I have a LLC020 on my VeraPlus using the ALTHue plugin, and the device is displayed correctly… The “urn:schemas-upnp-org:device:DimmableRGBLight:1” is a natively supported device type in UI7. It is used by the MIOS Hue plugin.
From the screenshots provided, it looks like the OP has not refreshed the browser since the device was added…
Again here is a screenshot … It just won’t show…
Both of these lights are Color Lights, one is the E27 bulb (Speelhoek) and the other one is a HUE Go.
Did you ever install the app OneEnabled or SceneFlow? In these apps the lights also don’t appear… Not sure if it has anything to do with it.
I think in might, since there is no On/Off button propagated…
If you have a look at your VeraApp, can you control the lights there? I can only turn them on or off. No Dimm function or color change.
Is that normal behaviour? (see screenshot)
Looks to me like your vera crashed (a familiar event) while installing the plugin. The cleanest way would be to remove and reinstall the plugin. You could add the attribute manually but who knows what else is wrong.
I moved back to the official App, and it all is working…
That on itself is strange, because I was never able to use that official app in the first place…
So, as a newbie on the Vera Platform I am slowly starting to understand the unpredictiveness of it all
No worries, I kind of like being able to fiddle around with it…
But bottom line, the AltHUE app is not really working for me I am afraid …
Thanks everybody for the help!
Much appreciated!
best,
Sander
