Hello @amg0,
ALTUI shows default z-wave icon instead of bulb light icon for Hue dimmable RGB lights.
Would it be possible to show the same icon than for Hue dimmable light please ?
Can you please give device id , device type , and device json exact values ( in advanced attributes )
Also the hue plugin data in the settings page
Thank you
Device id =384
device type = urn:schemas-upnp-org:device:DimmableRGBLight:1
device json = D_DimmableRGBALTHue1.json
Hue plugin data =
You see the tab « hue data « ?
I need the json text in that page
Thx
hue data json text.zip (7.1 KB)
can you confirm the model id of that device 384 ?
do you see the same model id in the file ALTHue/LightsAndIcons.md at master · amg0/ALTHue · GitHub ?
if not, we probably need to edit the file ALTHue/D_DimmableRGBALTHue1.json at master · amg0/ALTHue · GitHub to add that model if it is missing from the current list
Model ID = LCT015
Device _json = D_DimmableRGBALTHue1.json
In your file I found on Hue bulb A19 line : Model ID LCT015 => icons_hue_a19.svg
I also have LWB010 using the same icon showing fine in ALTUI.
if you have the latest version (GitHub - amg0/ALTHue: Alternate Hue Plugin) and if the file D_DimmableRGBALTHue1.json is present on your system, then please check the file and exact folder location for the file icons_hue_a19.svg. it should work
if you miss that file, you can get it from ALTHue/Icons at master · amg0/ALTHue · GitHub
Thanks amg0
I put github D_DimmableRGBALTHue1.json in Veraplus again.
I checked file icons_hue_a19.svg and it shows well a bulb light.
Restart VeraPlus, cleared Firefox cache but no change default zwave icon is still there.
Well it seems that my VeraPlus was corrupted as I got frequent (5mn) lua reboot.with another plugin - Reactor overloading memory. I tried uninstalling it and removing plugin files but reboot was still there with no clear trace in log.
I did a “factory restore default” and now icons are correct.
I discovered that some other icons (like Philips Hue plugin in UI7) have changed indicating they were wrong as well.
Thanks amg0 for your help.
