We published a new version of the plugin yesterday, 1.28, which should fix all the compatibility issues with the newer versions of the bridge.
We tested with versions 1.13.0 and 1.15.0 of the bridge, and didn’t find any issues.
The plugin is set to update automatically, so please check that you have the latest version - 1.28.
This same symptom just started happening today. I may be an outlier, or I may be the early warning…
Hue2 bridge with SW 1943185030 using Vera “official” Hue2 plugin v 1.79
The Hue firmware updated itself a couple of days ago. This morning, we had a power outage long enough to take down the UPS with Vera on it. After the power came back, Vera is doing its usual stuff – minus any lighting actions.
The Hue bridge reports it is connected/paired, but all attempts to send commands through Vera to control lights fail with “Command failed” message. Attempting luup.call_action() commands results in error -911, not ready.
The lights are controllable with the Hue app – just not with Vera.
Things I’ve tried: POPO Hue 2 bridge; POPO Vera; uninstall/re-install Hue2 plugin. No change.
I surmise there has been another change in the Hue API which has blown up the Hue plugin. The fact that the Hue firmware updated a couple of days ago, and Vera/Hue interaction was suddenly disrupted right after a power outage, seems to point to an inability to send commands to the Hue due to failing authentication, notwithstanding the bridge being paired.
I notice the new Hue App reports the Hue is “Secure via HTTPS”. I don’t recall seeing that before. Could be related.
Anyone else noticing similar issues?
EDIT: I uninstalled the Hue2 plugin (again) and installed AltHue… Vera is controlling the lights again. So it appears the issue, whatever it is, is probably confined to the “official” Vera/Ezlo Hue2 plugin.
Yes but if you look at the files for AltHue on github they have not been updated. Last changes appear to be 13 months ago. So nothing changed there to accommodate any changes to the Hue Bridge firmware.
It was all working; then one Hue firmware update and one power cycle later, zero lights were controllable. Reloads, reboots and reinstallation of the plugin didn’t fix it, but switching to AltHue did…
Maybe amg0 wrote his code in a more robust way, such that it didn’t break when the changes happened on the bridge? That’s exactly the reason I tried the AltHue plugin; to see if it also had issues - and it does not.
