While I can get the device name using something like this with luup.
local name = luup.attr_get ('name', lul_device)
print(name)
I can’t seem to find the command that gives me that via an external http request (I couldn’t see anything in here → http://wiki.micasaverde.com/index.php/Luup_Requests#device)
What are people using ?
Write your own handler. It’s easy to do and you could send whatever you want.
@therealdb
I’m obviously close, but no cigar yet, when you can please could you help me with the following so I know where I’ve gone wrong.
function lh_devicename (lul_device)
local html = "</html><head>" ..
"</head>" ..
"<body>" ..
tostring(name) ..
"</body></html>"
return html, "text/html"
luup.register_handler("lh_devicename","DeviceName")
When I try to call it with the device number variable -
192.168.102.107:3480/data_request?id=lr_DeviceName&31
192.168.102.107:3480/data_request?id=lr_DeviceName&lul_device=31
It returns
nil
I’ve checked the function works ‘as is’ print(lh_devicename (31)) so the issue I assume must be with how the variable is being passed ?
your code is not correct. try this:
function lh_devicename (lul_request, lul_parameters, lul_outputformat)
local lul_device = tonumber(lul_parameters["device"], 10)
"</head>" ..
"<body>" ..
tostring(name) ..
"</body></html>"
and call it via:
http://192.168.102.107:3480/data_request?id=lr_DeviceName&device=31
