How do I make a http post in a scene using LUA. Could someone post an example of the syntax please.
Good afternoon,
The following link should help you in that process: http://wiki.micasaverde.com/index.php/Luup_Scenes_Events
Regards,
Thanks. I did look there but i cant get it to work.
I tried this:
local http = require(“socket.http”)
http.TIMEOUT = 5
result, status = http.request(“http://192.168.1.90:81/admin?camera=RearGarden&alerts=2”, “run=run”)
But is doesn’t work. If I run the URL http://192.168.1.90:81/admin?camera=RearGarden&alerts=2 direct in a browser it works fine. But i’d like to have this command work as part of a scene.
On a Vera or Ezlo hub ?
Its a vera hun running UI7
On a Vera firmware hub you can just do this in your lua code:
luup.inet.wget("http://192.168.1.90:81/admin?camera=RearGarden&alerts=2") --Your comment here
thank you. Do I need the socket request an timeout code also?
Think you can just add a ,5 to the request.
luup.inet.wget("http://192.168.1.90:81/admin?camera=RearGarden&alerts=2",5) --Your comment here
That’s perfect. Works a treat. Thank you.
