I have a scene that merely runs an HTML Get command to a device. The string is 115 characters long but the ezlogic web interface doesn’t allow a string longer than 100 characters. Is there a way around this?
Also while you can create an HTTP Get as an action in a scene you cannot edit it later. You basically have to delete it and start over with each edit. That is cumbersome.
