Sorry for the noob question. I just got a Vera Edge from my fren and I’m trying to figure out how to send http command using LUA, but i just cant figure out how.
I was trying to create a “Virtual switch” that will send a http command of let say:
http://192.168.1.123:4000/turnoff
and put the command in LUA code of the device, but I cant find something like that.
Then I try to create lua scene, but it requires a trigger which i dont have any sensor yet at the moment, is it possible for me to create a variable of lets say xxx=1. and the scene will check if xxx=1 and run the http command if it is?
I’ve spent whole day trying to look for more info, but most of the explanation is quite confusing for me as I dont code, I just want to send a simple command. Thanks so much!
