No need to apologise. This is definitely a new topic!
I have a device that emits an xml message stream in response to receiving an HTTP get. The return xml schema varies by message content--there are approximately 4 different schemas that I can see, and messages are broadcast approximately every 3 seconds after the initial wget triggers the server response.
That’s pretty unusual behaviour, I’d say? I’ve never seen a device do anything quite like that before.
Does openLuup have a way to set-up a callback similar to the UDP style callback?
Yes. There’s at least three possible alternatives to explore:
[ol][li]create a separate HTTP server on another port (this should be easier than it sounds… in the end, just a one-liner, although the existing server code may need just a few tweaks.)[/li]
[li]open a vanilla TCP server (also a one-liner) and handle the HTTP protocol and XML schemas directly[/li]
[li]use the standard luup.io module functionality and write a plugin with tags[/li][/ol]
Which way to go would very much depend on the detailed behaviour of your device: what it puts in the headers; how it handles the connection; …
Is there a detailed description of that?
And secondly, I read the source code notes in xml.lua about the basic internal xml parser, but wasn't sure what the boundaries were for its use, or the syntax for calling it.
In one of those curious coincidences, in the latest release I have just removed the separate XML file, for a number of reasons. In particular, the caveat at the start of that module remains pertinent:
-- general xml reader: this is just good enough to read device and implementation .xml files
-- doesn't cope with XML attributes or empty elements: <tag />
-- TODO: proper XML parser rather than nasty hack?
You can still access the XML module, it’s now a sub-module of the loader, since that was the only user of its functionality, and I’ve currently hidden the decode() function, but it’s trivial to reinstate that.
local xml = require "openLuup.loader" .xml
What does the XML sent by the device actually look like? (I hate XML… JSON is so much easier)
The functionality I need is fairly straight forward. I need to start the message service via a wget which would activate the openLuup listener, parse the xml response (and reissue the wget if the connection drops), scan, and then act on the data.
As above, it really depends on the details of the device and it’s handling of the connection. I’m not yet convinced that what you ask is actually “straight forward.”
I know a listener can be done programmatically as many of the plugins do exactly that, but would much prefer a simpler call directly to openLuup to handle the listening. ;D
Wise choice. The Vera/MiOS model for this type of device I/O is deeply flawed. Not least, the ability (or lack thereof) to reopen a connection when it drops. So that’s my option #3 above, out of the running.
Any insights are greatly appreciated.
Well, there they are, FWIW. Your thoughts, now?
