We were debating whether to fix this “bug” or not. On the one hand this could be used to create cool stuff without using JS tabs. On the other hand this could be used for malicious purpose, though in the case of the plugin published on apps.mios.com this can be avoided by checking the plugin before publishing it.
Fixing this bug will also cause some plugins not to work anymore.
So, who’s for fixing this bug, and who’s against it?
I would say fix it but at the same time give some extra control types so that developers do not have to use this. For instance a img control that can load and show a custom image in a dashboard based on a HTML src coming from a variable.
Btw is there any doc on JavaScript tab and how to use jquery code in it ? How to hook in some code in the page $.ready(). Could be cool to be able to use jquery plugin to build custom device dashboards.
