I have 2 HSM100 3 way sensors. I set them both up identically. Now for some reason one has adjusted itself to produce a wattage value, and added the energy lines to the the advanced tab for wattas and log. the other sensor does not have the lines present at all. Anyone have any idea how to fix this? I tried setting the value in settings to zero and also in the log line in advanced. A few days later it showed up again, though with a different wattage number. Setup still shows nothing in the wattage line.
I have had this quirk a time or 2 and to remove all vestige of the innapropriate display I ended up excluding/re-including the sensor
PS: I havn’t had this in quite some time now, what firmware are you using?
