Greetings
Finally I received three HSM100/ Express Controls 3-in-1 , I have been eagerly waiting for. Read on earlier threads (too old - from 2008) that there may be older versions so allow me to ask how-to-tell as well.
Question #1: Does this sound old version
From Devices
Capabilities 81,140,0,4,33,1|49,96:2,112,114,119,128,132:2,133,134,
Version 6,2,40,1,9
Manufacturer Ryherd Ventures
Model Express Controls 3-in-1
Question#2: Motion Sensor does not trigger the lights or anything
One Simple Scene: Version 979
LuuP Event
Device : Motion Sensor
Event Type: A sensor (door/window/motion etc) is Tripped
Name of the event: GST Motion
Tripped: Yes
Commands: Lamp: ON : After 1 minute : Switch OFF
Sensor unchanged
Problem1: I do see motion with blinking LED but no lights
Problem2: After some time the LED on “Express Controls 3-in-1” goes off and no motion brings it back on
After reading and re-reading threads and above all the nice WiKi on this tried to change the parameters
Wakeup interval (seconds):: 360 (minimum possible with battery powered for testing and using rechargeable)
Problem1 and Problem 2: Still the same status
Custom Zwave Settings: Parameter 2 (Wake Up Time) Value 5 minutes (Size : 1 Dec as suggested)
If I click on Scene “GO” it does power on the lamp but nothing on Motion.
What am I missing? Will appreciate the pointers.
regards
- Keeper
