Hi All
Can someone explain to be what the association/grouping stuff does in the Vera setup. In my current (brand new) setup, I have a Vera 3 and a 3 zone HVAC controller by 3 x HRT4ZW and 3xASR-ZW.
Without the Vera, each HRT4-ZW is paired with an ASR-ZW and they all communicate independently.
With the Vera 3 in place, it seems we must create a single z-wave network of all the devices and then ‘associate’ each HRT4-ZW with it’s correpsonding ASR-ZW receiver.
Now, I have read two different ways of doing this.
a) Include all the devices with the Vera (L mode on the HRT4-ZWs / press the network button on the ASRs). Then manually assoicate each HRT4ZW with it’s ASR using the ‘A’ mode and the network button again.
b) Set up assoications in vera (UI5). This appears to involve assigning a group id under ‘Device Options’ under each HRT4 - ZW. However the instructions I have seen elsewhere are very vague. Should all 3 pairings be in the same group or should I assign groups 1, 2, 3? And what is the text box for to the right of the checbox in the ‘set assoication’ screen?
Thus far, I have had limited success with (a) and none at all with (b). However, I fear that the manual associations are being lost when Vera reconfigures the nodes or at least something is causing the ASR-ZW’s to go into ‘lost connection’ mode (network light on/steady). Also, the manually created assocations don’t seem to show up in Vera making me think that these two ways of working are not necessarily doing the same thing.
Hope someone who really understands Z-Wave can explain what is going on here and/or what I should be doing.
Regards
John Jameson
