HRDS1 sensor issue
I have a HRDS1 hooked up to my garage door. I have setup both an open and a close notification to be sent via SMS.
The issue I am having is that I receive two notification for either the open or close.
Do I need to setup a delay to so that I only receive one notification on the open or close? If so, where would I do that?
I have searched the forums, but I must not be using the correct keywords.
Thank you.
Mike
hi,
what did you put for the “tripped?”? yes, or no? you might have created a notification for both of them. you only need one.
