how to Wire Evolve LSM-15
Need some simple help on wiring Evolve 3 Way Switch LSM-15:
I want to know how to / which wires to connect.
I am replacing an existing 3 way standard switch with LSM-15. The standard 3 way switch has the following wires:
  • one green wire
  • one white wire
  • two black wires
  • one red wire
The LSM-15 has the following wires:
  • one yellow
  • one green
  • one white
  • one blue
  • one black
I realize the green is ground and the yellow has to be capped off (though I don’t know why), and the white is neutral, how do I connect the rest of the wires?
Thanks for the help.
I explained it as clearly as I could here:
http://forum.micasaverde.com/index.php/topic,15563.msg118440.html#msg118440
Thank you.
If you can kindly clarify one thing:
On the 3 Way switch that I am replacing with the LSM-15, there two black/gray wires that are the ‘travelers’, can you tell me where do I connect these two gray/black wires? Are they connected to the blue wire?
Thanks a million.
