I’ve been getting some (lots) of alerts from a device that runs one of my lights. It’s a Fibaro FGS221 which has previously worked fine for a couple of years.
It responds every time a command is sent, but Lua still claims that it’s not responding to polls. I seem to recall that when I initially added it, there were additional ‘ghost’ devices which were ‘removed’ by Vera support. Learnings on here seem to indicate that ‘removed’ in this context actually means ‘hidden’ and I therefore wonder if it was one of those devices that is actually screwing around.
So is there any way I can see hidden devices? Is this likely to be the issue?
Also i hide some devices in the past. Recently i wanted to check them so i generated a device list by using some luup code:
local file = io.open(“/www/devlist.txt”, “w”)
file:write("[DeviceNo / id] device names on " … os.date() … “\n”)
local idx = {}
for deviceNo in pairs(luup.devices) do
idx[#idx+1] = deviceNo
table.sort (idx)
for _,deviceNo in ipairs(idx) do
d = luup.devices[deviceNo]
file:write(string.format(‘[%03d / %s] %s \n’, deviceNo, d.id, d.description))
file:close()
Does this Luup script still do the job of discovering ‘Hidden’ devices on Vera? I tried it verbatim via the Test Lua window, and got an error message. Any clues?
local file = io.open("/www/devlist.txt", "w")
file:write("[DeviceNo / id] device names on " ... os.date() ... "\n")
local idx = {}
table.sort (idx)
file:write(string.format("[%03d / %s] %s \n", deviceNo, d.id, d.description))
file:close()
